SAVE UP TO 50% on Popular Products
Top 5 Best DVD Players with Netflix Streaming Capabilities
Netflix revolutionized the way we watch content online and not just on our computers. Movies and shows that are available on the platform can just as easily also be streamed to the large-screen TV of your living room. All you really need in order to pull that off is to attach your TV to a DVD player with Netflix streaming capabilities and you’re good to go. There are plenty of devices that allow you to do just that nowadays but it can sometimes be difficult to find the best option for your budget. Well, don’t worry because we did some digging and managed to find the best players currently available on the market, so all you need to do now is choose the one that works best for your specific needs.
Part 1: Top 5 Best DVD Players with Netflix Streaming Capabilities
DVD Player with Netflix:Panasonic DMP-BDT220
We’re starting off with one of the most expensive options available but one that’s totally worth the asking price if you can afford it. The Panasonic DMP-BDT220 retails for about $500 on digital marketplaces like Amazon so this one is definitely not for everyone. This is a smart DVD player with Netflix streaming functionality that even includes a dedicated button for the platform to make things as simple as possible. There’s built-in Wi-Fi to help you connect instantly to Netflix and a remote control app that makes it very easy to navigate and select the content you want to watch while you’re on the platform. The main reason why this player is so expensive is because it also supports Blu-ray movies and 3D videos in addition to DVDs so you can use it to watch pretty much any type of content.
dvd player with netflix
DVD Player with Netflix:Sony BDP-BX320
If you’re looking for a less expensive Netflix DVD player you can never go wrong with the Sony BDP-BX320. The price of this one currently sits at a little over $65 and is one of the cheapest options in this category. Don’t let its cheap price tag fool you, though, because this is a very capable player that also looks pretty stylish to boot. The BDP-BX320 is famous for its reliable Wi-Fi connection and its inclusion of Miracast technology, which allows it to mirror mobile devices. In addition to Netflix, the DVD player can also stream content from a wide variety of other platforms like Hulu Plus, YouTube, and many more. The player can handle both DVDs and regular Blu-rays but that’s about it. Still, if you want a Netflix DVD player specifically for DVDs and aren’t interested in 4K content or anything like that, this player will definitely serve you well.
netflix dvd player
DVD Player with Netflix:Oppo BDP-103
The Oppo BDP-103 is another expensive DVD player with Netflix and Wi-Fi functionality that will set you back even more than Panasonic’s offering because this one costs around $570 on Amazon. Certainly not cheap but you do get what you pay for. The player distinguishes itself thanks to its ability to offer almost unparalleled video and audio quality, as well as some nice bonus features. Although it can easily handle DVDs, the Oppo BDP-103 is primarily a Blu-ray player so you won’t have to worry about format compatibility with this one. The player is very fast and supports all the most popular streaming services, including Netflix of course. Another highlight of the BDP-103 is the fact that it includes several connectivity options such as HDMI, USB, and Wi-Fi, which makes it a lot more flexible than many of its competitors.
dvd player with netflix and wifi functionality
DVD Player with Netflix:Sony PlayStation 3
The good old PS3 was the first consumer-grade devices to include a Blu-ray player and is still a favorite of gamers everywhere. Of course, you don’t necessarily have to be a gamer to buy one because you can also use it as your go-to Blu-ray and DVD player with Netflix streaming capabilities. The PS3 may not be as advanced as some of the other entries on this list or even newer consoles like the PS4 or PS4 Pro, but it’s pretty cheap (around $100) and can definitely get the job done. The console is equipped with Wi-Fi and can handle Netflix content of up to 1080p resolution. One of the things that actually makes the console better than traditional players is that it comes with a 320 GB hard drive so you can use it to store quite a few movies whenever you prefer to watch something offline.
dvd players with netflix streaming capabilities
DVD Player with Netflix:Samsung BD-F7500
The Samsung BD-F7500 strikes a very good balance between price and playback capabilities. This DVD player with Netflix functionality retails at around $190 and offers quite a few more features than your average player. Just like the PS3, the BD-F7500 works best when playing 1080p content, however, the player does include a 4K upscaling feature so you can also use it for higher resolution content. 3D movies are supported as well and there are two types of connections available – Wi-Fi and HDMI. One of the major selling points of this player is that it includes built-in browser support so you can also use it as a basic computer to navigate the internet when you’re not using it to watch movies.
dvd player with netflix functionality
Part 2: The Best DVD/Blu-ray/UHD Blu-ray Player Software
If you’re still not sure about the physical players currently available on the market, it’s worth noting that a media player software can work just as well with a smart TV and you’ll end up paying less for it. The best player in this category we can recommend is DVDFab Player 5, and all-in-one media playback solution that can handle any type of format you throw at it. That includes not only DVDs but also Blu-rays and even 4K UHD Blu-rays, which is something many physical players still struggle with. You can use this player software to play DVD/Blu-ray discs rented from Netflix.
The software comes with navigation menu support for all the formats mentioned above and includes two playback modes – PC and TV. These two features combined make it pretty much indistinguishable from a traditional player and combine to offer an excellent viewing experience not only on your TV but on your computer as well. The player is nicely designed, easy to use, and comes with a wide range of customization options. A few other standout features include 3D upscaling, HDR10 and Hi-Res audio support, customizable playlists, the ability to quickly find specific scenes thanks to a new intelligent Preview feature, and much more.
best dvd player software
Price-wise, DVDFab Player 5 is more flexible than most other players out there. The Standard version will only set you back $59 while the Ultra variant costs $99(It will be even cheaper if there is a promotion). You can stick with Standard for most movies but you’ll need the Ultra version if you want to take advantage of some of its advanced features like 3D and 4K UHD Blu-ray playback. DVDFab Player 5 is available on both Windows and Mac and offers a free version so you can check it out without having to pay anything and then upgrade at a later time if you enjoy it.
Buying a good DVD player with Netflix streaming capabilities is a very good investment in this day and age because the platform is now home to some of the best content you can find. We only talked about some of the most popular DVD playerswith Netflix today but there are a lot more good players out there that might be more up your alley. But if you would prefer not to invest in new hardware at this time, getting a great piece of software like DVDFab Player 5 is also a very smart decision and we can guarantee that you won’t be disappointed by what this player has to offer.
Above all, you have known 5 best hardware DVD players with Netflix and a software DVD player with netflix. As a Netflix lover, maybe you usually rent DVDs from Netflix. Then do you want to backup Netflix DVD rentals? Here not only introduce 10 best romance movies on Netflix 2018, but also tell you how to backup them.
You maybe like these items:
DVDFab DVD Copy
$54.9
DVDFab DVD Ripper
$54.9
DVDFab DVD Creator
Burn any videos to standard DVDs
$42.9
Choose Language
English
