Old school MP3 players are rarely used anymore because nowadays you can have all the music you want on your phone and not bother with any other devices. However, if you truly want to listen to your favorite songs in style you’re going to need a good Android MP3 player app. As with all types of apps, there are plenty of good players to choose from, so all you need to figure out now is which app is best suited to your needs. To help you with that dilemma, we put together a list of the best MP3 players for Android you can find right now. Here are our picks:
You can also click top Android MP4 players to find the video players you want.
Google Play Music
We’re starting off with an app that wouldn’t necessarily be considered the best MP3 player for Android but is still worth checking out. We’re talking of course about the good old Google Play Music. One of the biggest advantages of Google Play Music is that it allows you to store all your songs online so you don’t have to worry about losing your music if you lose your phone or decide to change it. You can also import music from your other online libraries and gain access to various perks if you happen to be a YouTube Red subscriber. But even if you’re not, Google Music is overall a pretty decent free Android MP3 player regardless.
android mp3 player
BlackPlayer
BlackPlayer is a very minimalistic MP3 player for Android that wants to provide users with a simple and straightforward experience. However, that only applies to the free version of the app. If you’re going for the premium version, expect a lot of great features like customizable themes, equalizer, bass boost, tag editor, virtualizer, and many more. A great option both for those who like simple apps and for those who like their Android MP3 player with a lot of bells and whistles.
android mp3 player
Poweramp
Poweramp offers a lot more features than most other MP3 players for Android but you can only get it if you’re willing to spend a few bucks. Though there is a 15-free trial, Poweramp is largely a premium app that requires you to spend some money if you want to keep it for good. But is it worth it? In short, yes. Poweramp definitely delivers in terms of features and supports many different audio formats so you don’t necessarily have to stick to MP3 files. In addition, you gain access to a lot of playlist formats, lyrics support, graphic equalizer, tag editor, a couple of widgets and plenty of customization options to boot.
mp3 player for android
MediaMonkey
MediaMonkey is a bit less known than some of the other apps on this list but that’s exactly why we’re mentioning it. In addition to being a good MP3 music player for Android, the app can also be used as an audiobook, podcast, and even video manager. The app also offers that useful feature that lets you sync music from your computer to your Android device. You will need to download the desktop app in order to do that and the syncing process can be a bit complicated but it’s definitely worth it once you finally managed to set it up. The app is free but also offers a premium version with a few extra features.
Musixmatch
If you’re into karaoke or simply like to read the lyrics while you’re listening to a song, you’re going to love Musixmatch. The app has several features designed specifically for that purpose, including a tool that can identify the lyrics of the song you’re currently listening to and floating widget that displays them in real time. Interestingly enough, the widget also displays lyrics of songs you’re listening using other apps and streaming platforms like Spotify, SoundCloud or YouTube. This is technically a free Android MP3 player but you’re going to need to spend a few bucks if you want to get rid of the ads.
Musicolet
This app is for those who don’t care too much about fancy features that rely on an internet connection and just want to listen to their favorite song offline. The app doesn’t have much to offer in terms of customization but it does come with some nice features like tag editor, sleep timer, and a great playlist manager that you can use to queue up multiple albums. All that aside, this Android MP3 player also stands out from the pack because it’s not only completely free but doesn’t bother you with any ads either so you can always listen to your music in peace.
android mp3 player
Phonograph
Phonograph is a fairly new Android MP3 player that was designed to blend in with Android’s Material Design user interface. As such, the app will immediately feel familiar to Android users. There are multiple themes to choose from but the selection isn’t that great so it might be better to simply stick with the default one. The app isn’t rich in features but does have a good playlist manager, tag editor, home screen widget, and a couple of other useful tools. Might not be the best MP3 player for Android but the app is still new so more features will probably be added further down the road. Phonograph is also completely free and definitely worth checking out.
android mp3 player
And there you have it. As you can see, choosing the best Android MP3 player for you requires a bit of trial but luckily all these apps are free or have a free component (such as Poweramp) so trying them out won’t cost you a thing. Meanwhile, if you’re looking to play music on your computer we recommend checking out DVDFab Player 5. Not just another music player, this software can actually support all types of audio and video formats, including highly demanding ones like 3D and 4K UHD. Not only that but the player also provides navigation menus for any DVD, Blu-ray and even 4K UHD Blu-ray disc. This is a premium tool so you can expect a large variety of great features to enjoy. But you don’t have to take my word for it, check out the free trial today and see for yourself.
