How to Convert MOV to AVI Using DVDFab Video Converter?
Summary: Wondering how to convert MOV to AVI? Here is your best converter tool for you to convert MOV to AVI at ease. Go to learn the detailed conversion steps.
Wondering how to convert MOV to AVI? Well if you do then you better stick with this page. There are often times when we do feel like converting a MOV video file to an AVI one. But there are hardly any tools available online that does the job with ease.
Of course, there are so many tools are available online, and there is no doubt. But the question is how reliable those tools are?
As you already know that some of the tools come with a price tag and some of them are available free of cost. But again the question is how reliable they are? Is it really safe to install those software on our computer?
Well, most of the free tools are not free. Of course, those tools let you convert MOV to AVI files. But at the same time, they come with malwares or Adware. Hence it is not really safe to install them on our computer.
However, if you are looking for a MOV to AVI converter. Then we have something for you. We have handpicked this tool called DVDFab Video Converter which can convert any type of video formats with ease.
But before we go ahead and tell you all the steps that you need to follow to convert MOV to AVI Using DVDFab Video Converter. Let us give you a quick introduction to DVDFab Video Converter, so you can easily understand about the tool, and it’s features.
Introduction of DVDFab Video Converter Video Converter:
DVDFab Video Converter is an excellent software program that lets you convert any video files to any video format without any issues. It is also one of the most popular MOV to AVI converter tool available out there.
The tool can read almost all type of video formats that include MOV, AVI, MP4 and the other ones. Also, you can use this tool to convert videos downloaded from the internet. Or if you just want to convert a video from a digital camcorder or capture card. Then you will be able to do that as well.
The videos converted with the DVDFab Video Converter Video Converter can also be streamed on different multimedia devices, 3D devices, Android and iOS smartphones and so on. Also, the tool can be installed on your Windows and Mac computer. Plus it supports different Windows versions including Windows 7, 8 and Windows 10.
However, the tool is not a free one. You have to purchase the DVDFab Video Converter to convert your videos. But the software comes with a 30 days free trial. During this time you can test out the software without spending a single penny and if you feel it is a worthy application. Then you can go and purchase a DVDFab Video Converter license.
So that was a small introduction to the DVDFab Video Converter. Now just in case if you are wondering how to use the DVDFab Video Converter, well then here is the answer:
How to convert MOV to AVI Using DVDFab Video Converter:
Step 1: First of all, go and download the DVDFab Video Converter application and install it onyour computer.
Step 2: Launch it and after that go to the Converter module from the above menu.Then you have to add your MOV file to the DVDFab Video Converter.
Step 3: After that, you have to navigate to the profile library from the top left corner. Then click Format > Video > General to choose the AVI format.
Step 5: Then you have to select a directory to save the video output. To select a directory you have to click on the folder icon at the bottom and then choose a directory to save the output video.
Step 6: Click the “Start” button to start the process of converting the MOV video to AVI.
Once done, you are all set to use the video according to your needs.
So that was all the process that you need to follow to convert MOV to AVI videos. Apart from the MOV to AVI conversion, you can also convert AVI to MOV, Or MP4 videos to other video formats. Also there is a video editor option included in the software as well. Using that tool you can customize your videos, trim video, crop video, add subtitles and so on. There is also an advanced settings panel, which allows you to customize your settings easily.
Overall, the DVDFab Video Converter can convert all type of videos without any issues. So go ahead and have a look at it and see how it is working for you. Also for any questions, do feel free to leave a comment down below.
