[Review] HitPaw Video Enhancer: Best Option for Upscale Videos?
Summary: HitPaw Video Enhancer AI enhances low-quality videos into high-quality videos. But is it the best software? Be with us and find out in this thorough review.
Enlarge video resolution in up to 720p/1080p/4k
Upscale SDR videos into HDR standard and Dolby vision
Flexible customization of your videos with an editing Toolkit
A simple and efficient video creation tool is available
Introduction
While technology leaves no stone unturned to amaze us, content creators may face dissatisfaction with recorded video quality due to blurs or shaky effects. Regardless of the problem, they may seek an effective solution to enhance or upscale their video. Here's where the HitPaw Video Enhancer fits in perfectly.
HitPaw Video Enhancer AI is a user-friendly video editing app that enhances video quality. But will it put an end to all the video-related queries? Be in with us for a detailed HitPaw Video Enhancer review with its price, pros, cons, and usage. Also, you will be in for a powerful alternative. Just in case!
A Detailed HitPaw Video Enhancer Review
Upscaling and enhancing are essential parts of content creation. When you have to quickly improve a video's quality, software with an AI upscale option, like HitPaw Video Enhancer, could be exactly what you need.
HitPaw Video Enhancer is known for its upscaling feature that adds life to your videos. It is a powerful solution for video enhancement based on AI that can be used to enhance video quality and recover video details without the need to re-encode, edit, or tweak existing content with complex tools and techniques.
7 AI-Mode of Hitpaw |
General Denoise | Animation | Face | Colorize | Color Enhancement | Frame Interpolation | Stabilize |
Basic Infomation |
Features ✅ |
Cons ❌ |
How to Use HitPaw Video Enhancer
HitPaw Video Enhancer is simple and easy to use. Once downloaded, you can follow the installation process below. After installing, the process of upscaling a video is far from complex. Let's know how to use this software and enhance your videos.
Step 1: Open the official webpage of HitPaw Video Enhancer and install the app.
Step 2: Now, import the video you want to AI upscale to the software. You must click the Choose File or drag and drop the original video.
Step 3: Select an AI model out of its available seven models.
Note: Click the Add Model button if the models do not show up entirely on the main interface and download them from the Model Library.
Step 4: After uploading the video, tap the Preview button to process the video. Wait for a few seconds for this. Then, tap the Export button to save the enhanced video once you are satisfied with the results.
Best HitPaw Video Enhancer Alternative: UniFab
Undoubtedly, HitPaw Video Enhancer AI is a user-friendly software that uses AI upscale technology to enhance the videos, but the video processing is time-consuming, and it lacks advanced options for AI models. Instead, you can switch to using the UniFab All-In-One program.
UniFab is the best HitPaw Video Enhancer alternative, with the most comprehensive video and audio editing and enhancement solutions. Its AI-driven algorithms can add life to your dull videos and enhance them to the high quality of up to 4K.
Features of UniFab All-In-One
- Enhances and upscales SDR videos to HDR10 or Dolby Vision
- Restores low-resolution videos into 720p/1080p or 4K
- Supports video editing to meet your needs
- Offers 50x faster speed with GPU acceleration
- Upmix audio to EAC3 5.1/DTS 7.1 with AI
- Enhance video clarity for a realistic and more vivid visual effect
- Customize, convert, and compress videos losslessly
Step-by-Step Guide to Using UniFab
Launch and install UniFab and select the module.
Launch and run UniFab All-In-One on your PC and open the interface.
Load the source file and edit the output parameters
Select your preferred module and tap the Add Video button to choose the video to be enhanced in the local file.
Customize the restored video file
Customize the enhancement options, including enhanced resolution, video codecs, frame rate, and more. Then, tap Start and wait till the enhancement procedure is complete.
Output the enhanced file
After customization, you can output it right now or add it to the queue.
HitPaw vs UniFab
This table will help you further look at the two software at a glance.
Enlarge to 4K resolution | ||
Deinterlace videos | No | Yes |
Batch mode | ||
Upmix audio to DTS 7.1 | No | Yes |
Denoise videos and fix blurry content | ||
Suitable for all kinds of videos |
Besides video enhancement, UniFab is equipped with advanced algorithms to support multiple video formats and resolutions. Its unparalleled AI capabilities make your ordinary content extraordinary by refining each frame for an enriching video-viewing experience.
Yes, Hitpaw Video Enhancer is safe and secure with no viruses, malware, or spyware that can harm your computer or data. It also does not collect or share personal information or data from your videos.
HitPaw Video Enhancer offers a free trial, but it is not free. The Windows version is priced at $42.99 for a month, $99.99 for a year, and $349.99 for a lifetime.
No. HitPaw Video Enhancer crack is illegal and risky to use as these versions have malware and can cause damage to your system. As there's no legal source, you may compromise your data and make your system part of a botnet.
To Sum Up
Our detailed HitPaw Video Enhancer review has given you an insight into the HitPaw Video Enhancer program. Undoubtedly, it is the most efficient, modern, and advanced tool to solve all of your video enhancement problems and convert your simple and blurry videos into 8k videos. Batch conversion features also save users time. However, its AI models lack advanced options. So you can check a reliable alternative like the UniFab to upscale your video quality and improve it as a whole. If you want to know how to sharpen video quality, see our top suggestions.
