Do you want to convert m4v to mp4 efficiently? You might have encountered the most embarrassing situation when your media player reminds you that the current m4v file cannot be played? Despite the fact that there are numerous m4v to mp4 converter, easy to use yet versatile programs are few and far between. Anyway, this post offers you the best m4v to mp4 solution.
PART 1: Why Need M4V to MP4 Converter
It is an indisputable fact that M4V is a video container format developed by Apple Inc, similar to the MP4 format. The most essential difference between the two formats is that M4V files probably are protected by DRM copy protection since Apple applies M4V to encode video files in its iTunes store, which drives it difficult to share the files among the public.
Convert m4v to mp4 for a better play or share
In contrast to M4V, MP4 has been the most widely used and popular video format that is supported by almost all devices including media player, game consoles, TVs, or platforms including YouTube, Vimeo, Facebook, and Instagram. Considering this, it’s sensible to convert m4v to mp4 for a smooth playback and better sharing on social media sites for diverse uses. Hence, what’s the best m4v to mp4 converter? How to convert m4v to mp4 free and easily? To find the right answers, go and read through the next part.
PART 2: How to Convert M4V to MP4 with Most Versatile Converters
Among all possible m4v to mp4 converters, here comes the most versatile yet most professional desktop program, UniFab Video Converter Pro, a 3-in-1 video converter and editor that allows you to convert m4v to mp4 quickly and edit video files with tons of basic editing tools and creative effects.
M4V to MP4
This Video Converter is the best method for whenever you want to convert M4V to MP4 on Windows easily and efficiently.
Key Features:
  • Support to convert any video to 1000+ video and audio formats
  • Convert or compress videos to any video format without quality loss
  • Offer customized settings and a built-in video editor to make your video
  • Convert multiple videos with the Batch Mode
As the saying goes that each road leads to Rome, this versatile m4v to mp4 converter can convert m4v to mp4 free and fast in three simple ways. Check the following solutions with patience. No learning curve at all! Just free download UniFab Video Converter Pro and choose desired module to proceed with m4v to mp4 conversion task.
How to convert m4v to mp4 with best m4v to mp4 converter
Solution 1: How to convert m4v to mp4 with Video Converter
Install and select the Video Converter module on your device first.
  Free Download
  100% Safe & Clean
Learn More
  Free Trial
Select the m4v video you want to convert, and add it to the UniFab workspace.
m4v to mp4
Select 'Format', and choose 'MP4', click the Start button to finish the video converting procedure.
m4v to mp4
Solution 2: How to convert m4v to mp4 with Video Editor
Install and select the Video Editor Edit module on your device first.
  Free Download
  100% Safe & Clean
Learn More
  Free Trial
Select the m4v video you want to convert, and add it to the Video Editor workspace.
m4v to mp4
Select 'Export', choose 'MP4' as the video format, and then finish the video converting procedure.
m4v to mp4
If you are wondering how to use Video Editor from an overall perspective, click this link to get detailed information.
Solution 3: How to convert m4v to mp4 with Toolkit
When speaking of Toolkit, it is really a nice handy tool to edit video, audio, or image in simple clicks. This versatile toolbox can be well embodied by the proverb a sparrow may be small but it has all the vital organs. Now let’s check how it converts m4v to mp4 easily.
Install and select the Toolkit module on your device first.
  Free Download
  100% Safe & Clean
Learn More
  Free Trial
Select the Video Tools- Converter, and add the m4v videos.
m4v to mp4
Select 'MP4' as the video format, you can also customize other settings, such as video codec, resolution, frame rate, etc, and then finish the video converting procedure.
m4v to mp4
Sometimes you might want to normalize audio when watching a video footage captured on your own. In this case, do not forget to ask Toolkit for help.
PART 3: Conclusion
Now you might have got the hang of how to convert m4v to mp4 in 3 ways with the best 3-in-1 desktop software UniFab Video Converter Pro. Apparently, this m4v to mp4 converter works well for diverse purposes. Above all, it comes at a rather cheap price for full advanced features. Anyway, if you hate software installation when performing m4v to mp4 conversion, you might turn to online m4v to mp4 converters. But you need to endure pop-up ads when converting m4v to mp4. Most free online m4v to mp4 converters attempt to attract massive clicks via free conversion service.
By the way, there is other way out there if you want to enhance video quality via a professional video enhancer tool in order to upscale low-res videos to 4K. UniFab is always waiting for your free download.
