Back to School Deals | Start from Just $9.9 Storewide
Top 8 Best Screen Recorders for iPhone
If you would like to record your iPhone screen for office presentations, important video references, or anything else then we have some of the best and free screen recorder for iPhone devices listed below. In the list, you will find all kinds of apps ranging from simple ones to advanced ones.
The release of iOS 11, has also brought an inbuilt screen recorder to the desk but the inbuilt screen recorder lacks some of the main features like live streaming of games and other integrations.  If you are a user who uses iOS 10 or below version then also you can't use this new feature provided by Apple. In such cases, third party screen recorder for iPhone will come to the rescue. So without wasting any more time, let us check out the list.
1) DVDFab Screen Recorder & Editor for iOS
We have tried and tested many screen recording tools and out of all of them, DVDFab Screen Recorder & Editor for iOS stood to be the best. The software lets you capture screen, and at the same time perform professional editing with the help of features like trimming, cropping, adding animations, transitions, watermarking, etc.
The program lets you easily capture both video and audio playing on your iOS devices with the help of AirPlay Mirroring Feature. You can also provide voice over while you are recording video by creating PIP (picture-in-picture) effect. After your recording has been finished, you can edit your videos and before exporting them you have options to preview the edited video also.
The app is available at a price of $42.9, but trust me it is worth spending as you are getting everything at one place only. This will end up saving a lot of time of yours! If by any chance, you are still not satisfied with the product then there is also 30 Day Money Back Guarantee. To download the product, visit this page. (https://www.dvdfab.cn/screen-recorder-editor-for-ios.htm)
2) EveryCord
EveryCord may be something that you have never heard of or you would be unfamiliar with it. But, it is not at all like that! This app was formerly known as iRec and it has been developed by iNoCydia. EveryCord still holds the old features as it was before. The new change is that the developers have added support for iOS 10 and 11 firmware in this screen recorder for iPhone.
At the time of iRec, there were many crashing issues and hopefully, the developers would have taken care of those issues in this rebranded version. As of now, there is no live streaming support in the app but you can make some other significant changes through the settings page. Once you are done with any of your recordings, you can directly save it in your camera roll.
Overall, it is a fantastic app that sports an easy to use and clean user interface.
3) Vidyo
Vidyo is one of those apps which was once available on the official Apple App Store but it, later on, got removed as it featured the screen capturing option. It was available at a price tag of $4.99 and within few hours only the app had gained a lot of popularity due to the simple user interface it possessed and the features it had to offer.
Anyways, like its said, when one way closes, other way gets opened! Similarly, for Vidyo also we have a third party way. You can download the Vidyo iPA file and sideload it using Cydia Impactor or Xcode. You will need a proper running Windows PC, Linux or Mac for this installation procedure. The down factor of this procedure is that you will have to reinstall the app in every 7 days as Apple puts certain limitations on free developers.
4) BB Rec
BB Rec is another free screen recorder for iPhone which has major features like Vidyo. You can easily start recording your iPhone screen and broadcast it using a streaming server. Everything is right available through the app home screen.
The app has a very simple to use user interface and that is one of the main reasons for its popularity. In the main screen, you can find four options: Recording Screen, Live Recording Screen, Camera & My Videos. All your recorded videos can be found through the last option.
BB Rec is only available for iOS 9 and 10 firmware. To install the application, you can take the help of third-party app stores like vShare or Tutu Helper.
5) QuickTime Player
If you have a Mac computer and iOS device running with iOS 8 or above then you can easily record your screen without the need of any external screen recorder for iPhone. QuickTime Player is a feature provided by Apple itself that you can use to record your screen.
According to us, QuickTime Player is one of the best screen recorder app for iPhone. It is very simple and at the same time doesn't require you to perform any kind of jailbreaking or side loading of apps.
Steps To Record iPhone Screen Using QuickTime Player:
1) Carefully connect your iOS device to your Mac
2) Click on File >> New Movie Recording
3) Now,  a screen recording window should pop up. If your iPhone screen appears in it, great! If not, click on the down-facing arrow next to the recording button
4) Select your device name under Camera and you can also choose the quality of the mic
5) To stop your recording, click on the stop button located in QuickTime preview area. Your recording will be saved as MOV file on your Mac device.
6) AirShou
AirShou is a construction of Shou.tv creators which works pretty well on iOS 9 devices. With the help of Shou.tv, you can record your screen and perform live broadcasting. This feature reminds me of YouTube Gaming.
The program consumes very less processing power and still serves great output results. It works well for recording of popular games and applications as it can easily cover the whole screen of the iOS devices.
AirShou has integration with Apple's ReplayKit which makes gaming streaming very easy for the gamers. The procedure to get the app running up on your iPhone device is a little technical and at times, it won't run at all only. So if you are looking for some everyday usage iPhone screen recorder then I doubt that AirShou is not for you.
7) TechSmith Capture
TechSmith Capture is one of the most advancedscreen recorder for iPhone. With the help of this app, you can record live video calls, tutorials, presentations and the list goes on. The app works well on iPad and iPhone running on iOS 11. Using global recording APIs, one can also record full-screen videos of more than one screen.
8) Reaction Cam
It is a very unique app that lets you stream videos online and also record them. It has a clean and simple to use user interface. You can record yourself through the camera and catch your reactions and share it on different social media websites. If you want you can also live record any web browser activities that you are performing. Quite cool, isn't it? Visit here to download the screen recorder for iPhone
Final Words:
This was our guide on the top 8 free screen recorder for iPhone. We hope that this article will help you find the desired tool that meets your requirements. If you liked the article, please share it with your friends. Thank you.
 and if you have any other queries or recommendations then you can comment and let us know.
You maybe like these items:
DVDFab DVD Ripper
$54.9
DVDFab Blu-ray Ripper
Rip Blu-ray to various video/audio formats
$64.9
DVDFab Blu-ray Creator
Burn any video to standard Blu-ray
$42.9
Choose Language
English
