Quick Solutions to YouTube Not Responding Issue
YouTube is the most popular video streaming site. If you are an internet user, you cannot just live without using YouTube because it has become a synonym of videos as whatever you will search on Google, you will get the YouTube videos of that along with text search results.
But, like any other service, you may face issues with YouTube as well. “YouTube not responding” is an error that many users are facing when they try to access YouTube. To help those users, we are here to share the quick solutions to fix YouTube not responding issue.
Part 1: Most Common Solutions to YouTube Not Responding issue
1.       Clear Browser cache, history and Cookies
Since we use the web browser all the time while accessing the internet, there is so much cache and cookies get saved. And, due to piling up this much data, many times various websites stop loading. YouTube is one of them which sometimes stop responding when there is so much space covered by cache and cookies in the web browser.
So, to fix the issue, clear the browser cache, history and cookies by going to browser’s settings. In Google Chrome, you can directly enter chrome://history/ in the address bar, and click “Clear Browsing data”. Then, below screen will appear.
solution to youtube not responding
Select the desired options, and click “Clear Data”. This will take few moments to get the data cleared. This should fix YouTube not responding issue but if it doesn’t, let’s move to another solution.
2.       Uninstall Incompatible Browser Add-ons and Extensions
We use a lot of add-ons and extensions in our web browser to enhance the user experience and to do various jobs. Sometimes, due to some issues, a few extensions or add-ons may become incompatible. In that situation, the browser starts behaving haywire. It could be the reason why YouTube is not responding. So, uninstall those extensions and add-ons, and fix the issue. Most of the times, issue gets fixed, and YouTube starts working but if it doesn’t, let’s check out another solution.
3.       Upgrade the Browser
If you are using a web browser which works with outdated technology or if your version of a popular web browser is not updated with the latest release, YouTube not working issue may happen. So, it is always good to upgrade your browser, and use the latest.
4.       Check Internet Connection and Speed
Most of the times slow internet speed may be the reason of YouTube not responding because most of us nowadays play HD quality videos which takes more bandwidth. In this case, if internet is slow, issues are likely to happen. So, do check if your internet connection is working, and you are getting proper speed.
5.       Update Adobe Flash Player
Make sure that your browser’s flash player is up to date and working properly. Flash player is important to play videos in the browsers.
Part 2: Fix YouTube Not Responding Error for Good - Download YouTube Videos
From the above, you can learn that there are various causes and solutions to YouTube Not Responding, so sometimes you may need to try all of the solutions to fix the problem. Therefore the fixing process may not be so pleasant. But don’t worry, here we will recommend you a simple and fast way to avoid the YouTube not responding problem when you meet in watching online YouTube videos. The method is to download the YouTube videos and then watch them without any restriction and disturbance.
When we talk about downloading YouTube videos, DVDFab YouTube Video Downloader is the best tool out there. By downloading videos, you make them available for your offline use which you can later play on your PC using any video player.
Here are the steps:
1.       The first step is to download and install DVDFab 11 on your PC.
2.       Launch it. You will see the main user interface of the software.
3.       Now, click “Utilities” and click “YouTube Video Downloader”.
4.       A separate window for YouTube Video Downloader will be launched in which you will see integrated YouTube.
5.       Type the song name in the search bar, once found, click to play it. There you will see a “Download” button. Once you mouse-over that, you will see download options.
download youtube videos
6.       Click on any resolution option to download. For example, click “HD (720p) - .mp4”. Then click “Download” tab to see the download progress.
In a few moments, the video will be downloaded. Now the video is available for your offline use. You don’t need to go to YouTube and face errors. Just play that using any of your favorite video players.
This is the best solution if YouTube is not responding.
YouTube is the most popular video streaming website, and it has been being updated with latest technologies. So, for many, such issues happen when they don’t have upgraded modern browser on their PC. Even when cache and cookies are piled up, YouTube not responding issues happen. So, we have shared the solutions that you can use to get rid of this issue. And the best method is to download the YouTube videos you want to watch with DVDFab YouTube Video Downloader.
You maybe like these items:
DVDFab YouTube to MP3
Download YouTube videos to high-quality MP3s
$19.9
DVDFab Video Converter
Convert videos to various video/audio formats
$44.9
DVDFab DVD Ripper
$54.9
Choose Language
English
