How to Copy DVD to DVD in an Easy and Professional Way?
Are you looking for a versatile, powerful yet user-friendly DVD copy tool to back up your DVD movies? Then you can never miss out DVDFab DVD Copy. As a professional DVD copy solution, it provides you six copy modes and allows you to copy DVD disc to ISO file or DVD folder. In addition, its interface is modern, sleek and intuitive, so everyone even a novice can learn it quickly. Now let’s have a look at how to copy DVD to DVD with DVDFab DVD Copy.
Step 1: Choose a copy mode
Run DVDFab 11, go to Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes to choose. Here I take Main Movie mode as an example.
how to copy dvd to dvd in an easy and professional way
Step 2: Load the source
Insert the DVD disc and DVDFab will load it automatically. Or you can click the “Add” button to load the source manually. If the source is an ISO file or folder, you can directly drag it to the main interface to load it.
Step 3: Customize your DVD
After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and make advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "Folder" icon is to save the output as a DVD folder; to select a directory by clicking the "Image" icon is to save the output as an ISO image file.
Note:
6 modes:
If you choose to save the output to a blank disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the copy process. Please refer to DVDFab DVD Copy for more detailed information.
Choose Language
English
