Back to School Deals | Start from Just $9.9 Storewide
How to Rip DVD Movie with DVDFab DVD Copy for Mac?
How often do you rip your DVDs onto you Mac HDD to watch, or you simply insert the disc into your Mac disc tray and begin watching? Well, to save your original DVDs from being scratched or accidentally damaged, you’d better rip them off onto your Mac HDD and then watch them any time you want. As a powerful yet easy-to-use DVD copy software for Mac, DVDFab DVD Copy for Mac is able to help you finish that with just three simple steps.
Check it out to see how:
Rip DVD on Mac: Step 1 >After downloading and installing DVDFab 9 for Mac, start it and and choose Copy option in Option Bar, and then load the DVD you want to rip;
Rip DVD on Mac: Step 2 > Select one copy mode from Mode Switcher, like Full Disc, or Main Movie, or Clone, choose an output size on the Left Pane of DVDFab main interface;
Rip DVD on Mac: Step 3 > Select a directory from you Mac HDD to save the result at the “Save to” section, and then press the Start button to go ripping.
Note:  You can even select to choose a certain chapter range of the movie title, some certain audio tracks and subtitle streams to copy if you choose the Main Movie mode;
Software you need: the latest build of DVDFab 9
Product you need order: DVD Copy for Mac
 For further information, please visit www.dvdfab.cn/dvd-copy-for-mac.htm.
